Edit PIM Interface Parameters
Edit PIM parameters for an interface to customize the PIM configuration.
  • Before you change the state (active or passive) of a PIM interface, first disable PIM to prevent instability in the PIM operations, especially when neighbors exist or when the interface receives streams.
  1. In the navigation pane, expand Configuration > IP.
  2. Select PIM.
  3. Select the Interfaces tab.
  4. Configure the required parameters.
  5. Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
Name
Description
IfIndex
Shows the interface Index. This variable is a read-only field.
Address
Shows the IP address of the PIM interface. This variable is a read-only field.
NetMask
Shows the network mask for the IP address of the PIM interface. This variable is a read-only field.
Mode
Shows the configured mode of this interface. The valid modes are SSM and sparse. This variable is a read-only field.
InterfaceType
Specifies if the interface is active or passive.
DR
Shows the router with the highest IP address on a LAN designated to perform these tasks.
HelloInterval
Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default is 30 seconds.
JoinPruneInterval
Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default is 60 seconds.
CBSRPreference
Configures the preference for this local interface to become a C-BSR. The C-BSR with the highest BSR priority and address is the preferred BSR. The default is –1, which indicates that the current interface is not a C-BSR.
OperState
Indicates the status of PIM on this interface: Up or Down.
